Hi all
I have a basement which is below ground level on the 2 external walls. These walls were re-tanked about 15 years ago and no obvious moisture has come in since then. After having a musty, damp smell I lifted the carpets and there are now damp patches on the concrete floor ( please see pics ). I have put a damp meter on the 'dry' spots on the floor well away from the walls and the meter still shows dampness, and where the obvious damp patches are next the the outside walls damp is showing on the meter up to about 30cm above floor level, but not much above that. The property was built in about 1900. Any advice o how to treat this problem, I was wondering whether trying the concrete with a de-humidifier first then applying something like https://www.kingfisheruk.com/epoxy_primer-item-70 would help?
Thanks for any advice.
