Flat roof, no access to roof, trimming a joist
18 Oct 2018
Hello. I wonder if you could help with a question to see if I need to invest in a Structural Engineer and progress with a small project
Situation:
  • three storey house
  • no access hatch
  • joists at 16 inch centres
  • Joist span c. 3720mm/12' 2"
  • Want to create structural opening c 860mmx860mm, requiring trimming of one joist for energy efficient access hatch
Complication - sistering of joists would require removal of ceiling and the cost/disruption would kill the project.
Questions - in practice do I need to sister the joists either side of the cut joists? Would building control insist?
Do the answers change if the structural opening is next to a brick supporting wall, changing spans?
Would be very grateful for any pointers -if an SE and/or Building control are likely to insist sistering is needed, I'll put it on the back burner . Many thanks in advance.
Form a smaller hatch?
Use timber binders in the loft to avoid doubling the joists
Can't access be obtained by cutting a 16x 16 (or one dimension bigger) hole through the ceiling, then adding sisters or other strengthening from above, then remove a joist part for the hatch ?
That way the ceiling stays and minimal mess.
Sorry everyone, I missed a key bit of info. It's a flat roof, no roof space other than between joists
So you want to create an external access to the flat roof?
That will be fun.
Am I reading that right 12"x2" joists at 16" centres spanning 3720mm? They are massive joists at close centres, especially over that relatively small span. It would be a relatively simple calculation to work out if you could insert an access hatch but my gut feeling is it would be fine without additional strengthening.
I've made a pig"s ear of my question... The joists are 8 inches by 2 inches in cross-section with a span just over 12 feet. The roof is, from the joists upward, woodwool board, concrete screed, insulation, OSB, GRP . Built in 1963, upgraded recently.
Ah, 8x2's that's more like it. Could be a close call, but like I said it is an easy calculation so I would be surprised if a structural engineer charged more than £100 (doesn't include site visit).
