Electric under sink water heater
8 Aug 2019
Hi there
I’ve bought a Perfect WIJAS 5.5 under sink instantaneous electric water heater for a bathroom sink
We’ve installed it but it won’t work
The bathroom is in a flat and gravity fed by a tank in the loft
It says it requires 1 bar pressure which there is because I’ve measured it still there doesn’t seem enough pressure to activate it
Any advice much appreciated
Cheers steve
1 bar pressure from a loft tank seems unlikely - equates to around 35' head.
You say that the heater 'doesn't work' - what's actually happening/not happening?
What are the power supply arrangements for the heater (5.5kW)?
The heater will likely have a switch that only activates at a certain pressure, similar to electric showers.
If its wired in properly, and you have power at the unit, then its simply a case of the water pressure just not high enough to activate the unit.
It's possible the block of flats has roof cisterns feeding all the flats .......and the OP is on the ground floor of a 3 storey block:unsure:
Normal atmospheric pressure is about 1 bar. Methinks the required water pressure is 1 bar gauge, i.e. 1 bar above atmospheric.
