Hello,
We had a new rad fitted by a plumber last Friday. The system was drained down to facilitate this (tails needed moving).
Anyway after the job my hot water didn't work, i bled the coil which fixed that. Now i have noticed that the overflow (which is snapped off at the wall) is dribbling down the side of the house from the loft. This is to the point that, its gone through the brick into the plaster on the inside of the house and also making the oak frame window expand.
Ive been up here and i can hear the bigger of the two tanks (the cold water for the cylinder i think), does continue to run a fair while, so i think its that. Now problem is there is no access to adjust it, the roof is far too low. I can just get my phone in to take a pic. Strange thing, there is no lid, but there is an insulation jacked floating inside, under that ball cock. Is that normal?
I cant reach the ball cock to make any adjustments unfortunately.
