I had a brass equilibreum valve once, very expensive, I particularly remember the makers said you had to use a 6-inch copper float. I presume it takes a lot of leverage to shut it off securely.
Don't know why, the more modern plastic equilibreums have a tiny float.
It might help to bend the arm so the float sits lower in the tank and would be fully submerged before it overflowed.
AFAIK they are not widely used, I seem to remember they were popular on farm livestock trough supplies where pressure can vary a lot.
Thanks. I have bent the arm, but it still doesn't shut off. Will get the float you suggest and try that.
I live in a rural village ... maybe the pressure varies a lot ... similar to the livestock troughs you mentioned.
Cheers
