- Joined
- 13 Sep 2017
- Messages
- 50
- Reaction score
- 8
- Country
I know there are a lot of previous questions about prepping and painting MDF. I believe what I'm asking about is slightly different, however (having read previous threads).
The short version is that I'm after a white paint which I a) reasonably easy to get a decent finish with and b) tough enough for an area which will be prone to knocks and scuffs.
We have had 2.4m MDF threshold installed as part of getting some bifolds. I'm struggling to get the thing painted and was hoping the gurus might have some tips and recommendations. Here's what I've done so far...
[FWIW - the French doors just replaced had a gloss painted threshold which was still perfect after 20 years - i.e. I'm not looking for something which will stand up to abuse.]
The new threshold came primed. I have primed again with Leyland MDF primer (it had a few sanded patches, filled screwholes etc). Sanded smooth.
A decorator's centre suggested Bedec Multisurface Paint (soft gloss). I've not gotten on with this. It's apparently got a quick drying time and is difficult to get on smooth at the best of times. In the hotter weather, I struggled even more brushing it.
I sanded back and got up early when it was cooler to try a foam roller. Disastrous. A dreadful heavily dimpled orange peel. I did consider trying to pass this off as an "anti-slip finish" for a second
. I think this could have worked, but my inability to lay off and get an even coating very, very quickly is the issue.
I have sanded back flat again now with 120. Strangely, a handful of small chips appeared during sanding going back to nearly bare MDF. I have primed those and plan to level up with Toupret and prime, sand again.
I'm hoping for some recommendations on an alternative paint. I have been trying the multisurface paint on another test piece of MDF and although I can get a slightly better finish by improving my brush technique and dampening the surface before starting, it's still not great and very difficult to lay off neatly given the long length - at least for me.
I also understand now that this paint is a) not needed here since I'm priming and undercoating and b) has a very long (one month) cure time to be fully hard.
I am not too fussy whether we go gloss, satin or eggshell (it's white) on this. Getting a good finish which is tough is much more important. I read that Scuff-X is possibly an option here.
Any other suggestions?
