So Iv changed the rose light to led. All went well. However, Iv been informed that I should put the wago connectors in a junction box before putting back in ceiling. Is that correct?
Informed by who, as far as i know the connecters would need enclosing if pushed in the ceiling, if they are below the ceiling and within that fittings base then they do not need a seperate enclosure.
If the fitting is marked DOUBLE INSULATED then things would be different.
QUICKFIX- JB3 - Maintenance-free junction (Includes Wago) DESIGNED FOR USE WITH WAGO 221 SERIES CONNECTORS Specifications Designed for cable sizes 1.0MM, 1.5MM & 0.75mm flex Can handle up-to 16 amps. Complies with BS5733 & 18th Edition Wiring Regulations. High-Quality Polypropylene Material...
