- Joined
- 17 Apr 2024
- Messages
- 27
- Reaction score
- 3
- Country
We’ve built a porch. Owing to the slope of our front garden we have 4 steps taking you up the 2.5m approach to the front door.
Before the porch we had a sloped path to the old front door.
The steps have 150mm rise each, except for the first one, as you step off the existing path, which has a rise of 180mm-200mm. At a glance it looks like the other 2 brick rises.
Questions:
Step - Is this likely acceptable to building control, rise as it’s the first step? The slope away gets steeper the farther from the house you go so it’s proving a challenge.
I imagine the fix would be simply to increase the slope of the existing path a tiny bit so that is an inch higher where it meets the first step.
Hand rails: is it always flagged on private dwellings, when there are 3 steps or more leading to a front door? I ask as we’ve noted some similar steps in our street with no hand rails.
We don’t want to fit one unless forced too.
Length: if we do fit one does it need to run the whole length (inc 300mm past first and last nosing)? Or just alongside the top 2 of our 4 steps.
Width: I see a rule about width of steps and hand rails both sides. Our first 3 lowest steps are each 900 wide, but the final 4th step is 1,200mm wide with 900mm going (a sort of platform at the front door rather than). Does that force us onto a double hand rail?
Its all a bit maddening as the steps take you up the garden slope, so we don’t get very high above the garden at all, even at the top.
Questions:
