- Joined
- 2 Sep 2025
- Messages
- 3
- Reaction score
- 0
- Country
Hi all,
I’ve purchased samsung built-in single oven
Samsung nv7b57550tak.
I have dedicated ring directly from consumer unit, buried into mortar, on a 40a mcb with 6mm cable to connect the oven with.
As installed by my builder.
My questions are,
1)Is the mcb/cable setup acceptable (can 40A be used with 6mm cable)
2)what isolation switch do i need to add, in the kitchen? Does it have to be 40A or 45A because of the mcb size or can i have smaller one for example 20A.
(Spec says that oven has max 3950w power output and it seems to have 16A rating)
Appreciate an advice
Regards
My questions are,
Regards
