I'm pretty new to this so please forgive my lack of correct vocabulary or knowledge. I have a GE front load washer that has started leaking. I'm fairly handy and I was hoping I could fix it myself as buying a new washer wasn't really in my budget right now. I was hoping I could get some help understanding what's causing this issue and how I should handle it. So far, I've remove both the bottom front panel and the top panel. The leak is coming from the bottom of the machine and it seems to me like the bolts that hold the outer drum together is where the leak is happening. I've tried tightening the bolts but that has not worked.
