I've just installed a bypass valve on my central heating so as to avoid having to have a radiator turned on all the time.
I've installed a tee just before the 3 way valve input and another tee on the return pipe from the hot water cylinder, the bypass valve sits between the two. The directional arrow points from the 3 way valve end tot the cylinder return.
I've tried testing it as follows:
1. Controller set for Central heating "on", hot water "off"
2. There is a valve in the feed to the central heating circuit - I've shut that.
Unfortunately the pipe leading from the new bypass valve (to the return feed) does not get hot - so I'm concluding the bypass valve isn't working. In the scenario described should it be working?
I've another possible issue that I discovered while trying to troubleshoot the bypass valve issue. There are two pipes that disappear into the floor that only get hot if central heating is "on". As one gets hotter first (it leads from the 3 way valve), I'm assuming that this is the feed and return to the radiators. Under the floor must be a distribution manifold or similar. Here is the odd part (to my thinking): If all the radiators are switched off (via their TRVs), the two pipes mention still get hot. I don't understand why that would be so if there is no radiator turned on. Is it possible that there is a bypass valve (or similar) on the manifold?
Thanks in advance for any replies.
