Hello,
I live in a recently built home, the room height is very low, around 230cm, currently the lights are like these in attachment.
I wonder if there is any solution like a ceiling cover to not only hide the LED bulbs, but also to raise the cable that comes out as I touch them often…
In this case I could push it up (but it’s like forcing a brick wall, maybe an electrician needs to cut it…) or I can put the cable around in a circle, but I’m pretty sure that it will create shadow or it will be visible…
Essentially, I want to be able to replace the bulbs by myself, as it’s a very common failure and I can’t pay an electrician multiple times per year…
So, I don’t want ceiling lights with integrated LEDs.
