Hi all,
Converted office into a shower room. Builder fitted ceiling extractor fan with non-insulated ducting, vents outside through soffit.
Problem is when showering condensation starting to run on walls, water drops formulate on ceiling and additionally pool of water starting to form on rim of extractor fan, which fan trying to suck inside ( which i think is dangerous), as seen on attached video.
I think this fan is too weak and ducting needs to be insulated. Builder is adamant he done everything properly so I think that's falls to me to sort up his mess.
My plan is to buy in-line extarctor fan, something like Manrose MF100T, and a length of insulated flexible ducting. From pictured you can see how ducting goes at the moment. I'm thinking of installing new fan on raised platform to try to have constant rise to the fan and then drop to outside vent. Existing fan max flow rate is 80 m3/h, whether new one would be between 180-245 m3/h, so 2 to 3 times better.
Do you think I'm correct in my assumptions that new set-up might sort out the problem?
