not ideal but somthing like sandbag/sandsnakes placed to look like giving support to hold the frame down so wont look out off place at least in the short term
Thanks the holes now filled and the square patches back on top of synthetic grass. Just that it dips moq in the square and yiu can clearly see the square patches.
Had anothet company out for a repair quote this morning and they said perfectly doable job to level up and only need to go back a few feet and will connect the disconnected cut patches of synthetic grass back together to be less visible and attach them back down so they dont move upwards.
Said its no problem. A bit faffy but not an issue.
Hopefully he does he means it and will come back with a reasonable quote. And wasn't just saying that and doesnt really want the job.
He said that it would have not been realistically possible to not break the concrete out and remove the swing for the original company to fit and lay the synthetic grass. He said it could have been possible by cutting joins and left the swing in place and not touched the swing concrete footings or lift the swig up but cant tell if thats how they did it. Most probably they didn't. Just his opinion.
Here's a photo of how it looks today with th3 concrete refitted and the patch of grass loosely put back on the top.
