Fitting extending arm TV bracket to Plasterboard
30 Mar 2010
Rhondda Cynon Taff
Yes I know ideally screw into wall stud....
Its a small space - wardrobe one end, window the other so no stud partition available.
Its medium size TV - 15kg.
I bought some super heavy duty plasterboard fitting (https://www.amazon.co.uk/dp/B09KLQNXMW?ref=ppx_yo2ov_dt_b_fed_asin_title)
BUT it says "not suitable for extended arm TV"
Any suggestions?
I was thinking maybe 20cmx20cm square piece of wood attached to plasterboard using these fixings with TV bracket then screwed into this might be "slightly" better.
I wouldnt trust it without atleast one screw into a stud.
I fitted a tv on a plasterboard wall recently, I removed a local socket face pushed a rod down each way and located the nearest stud, easy peasy.
Hmm yeh thats what concerns me....
Deffo no stud - its behind the wardrobe now.....
Is there a solid wall behind the plasterboard?
Those fittings will only work in plasterboard up to 15mm, but I guess you mean drilling through the board, using the fixings in the plasterboard and then possibly using longer screws.
If external wall, you can use Corefix fittings...
I have only used Corefix a couple of times. I was (mostly) impressed with them. I initially used them to fit shelving racks in my garage. The walls were battened plasterboard over thermolite blocks. 80% of the fixings grabbed well, not sure that I would rely upon them for an arm that only has 6(?) fixings.
They are extremely strong fixings....
4 fixings :(
As in drill hole into breeze block behind? Corefix Connect type I assume?
The USP of Corefix is that it has an internal metal collar which spans the blockwork and plaster, thereby reducing the risk of the fixing pulling down through the plasterboard.
