Hi All,
New roof, with breathable felt and eaves vents installed two weeks ago.
Reason for the new roof was condensation with last roof (Bitumen Felt and Rosemary Tiles).
I have been monitoring the conditions in the loft. Temp & humidity.
There are a few wet spots on the loft boards, which I am hoping is just drying out.
The hygrometer I used is calibrated and the values its reporting are very close to external conditions. What this means is that due to current weather over the last two weeks its 80+ humidity in there.
The landing and house are approx 60% humidity (via 2 dehumidifiers). The loft hatch is sealed. The landing temp is higher than the loft, but given loft is similar to outside, I don't think much warm air is getting into the loft.
How can I tell if the new roof is working as expected? How can the few wet spots be explained?
I did a question in google Gemini, its says its bad; I did the same in Chat GPT, it says no problem.
Might be the wrong place to ask, apologies if it is.
