Hi all,
Last weekend I attempted to fit a 'self install' smart thermostat at my Mum's house, which is a job I've done once successfully before.
Everything was going well until it came to fitting the wires from both the existing power to the boiler, and the smart thermostat's wires into the same port's on the terminal block. The ends of the flex wires had ferrules on them, and after about an hour of messing around I managed to get the brown live wires into the port to an acceptable extent (that's after repeatedly crimping the ends into all types of shapes).
No matter what I tried I couldn't get the blue neutral wires into the block fully, so I had to abort the job, I would of had trouble being completely comfortable that everything was safe.
If I remember correctly, the last time I did one of these, it was an old boiler and the wires didn't have ferrules on them. I just twisted them together and fed them into the ports.
Would it be possible for someone to suggest the best way to solve this problem? I've been quoted £180 for a heating engineer to install, but I feel like it deserves another shot after spending 3-4 hours messing around with it last week.
Here's some images to give further context:
Before install (there's not a huge amount of room to work in):
The extent I managed to fit live and neutral wires:
The thermostat came with these parts, but I couldn't work out how I'd utilise them, or if there would even be enough room to make something like that work:
Appreciate the help.
