My step bricks have slumped down over the years which I want to re-lay. can anyone tell me how I can get them out without damaging them please as I tried a crowbar which didn't work and I stopped for fear of chipping them ?
Drill a hole, in the centre of one, so you can insert a screw and plug. You can then lever the brick up using the screw, and a crow-bar. Get one up and the rest should be easy. When you relay that first brick, simply lay it with the opposite face up.
Surely one of them can be levered up, where the gaps are bigger? You can probably loosen them by digging out whatever's between them with a suitable screwdriver or similar.
