- Joined
- 27 Jan 2008
- Messages
- 28,250
- Reaction score
- 3,432
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
The balancing game is complex, I remember talking to department managers about projected down time for machines, which would change their decision as to if worth moving labour to another machine, but to project how long it will take to locate a fault is hard, once fault is known OK, but once fault is known often just a couple of minutes until running again.
OK we can work out that during the adverts in the world cup the power use may go up as kettles are switched on, but with batteries even that is absorbed locally.
Talking to neighbours it seems this area smart meters don't work, the reception required is simply not there, so they are not being fitted in this area, so I will just need to use the two meters, one import and one export.
