Dishwasher - where to install water supply and drain hose
8 Sep 2008
London
just wanted some instruction on where to install the water supply and the drainage hose. The images might not show the necessary bit. Washing machine is to the left.
That's the washing machine pipe?
Yeah. That will do.
Look like you have access hole in cupboard ready if you want to use
Yeah. That will do.
Yes that's the washing machine pipe. Thats the normal place to fot the T connector?
And is this the drainage pipe that needs changing to the one in the link? Thanks for the help
That link seems to have a single appliance connection, like the existing one.
You need one with two appliance connections, one for the existing washing machine hose and one for the new dishwasher hose.
Search for “MCALPINE DOUBLE APPLIANCE TRAP”.
T off cold water pipe
You can either use a “Y-Piece” to tee downstream of the existing washing machine cold valve, or you can cut the copper pipe upstream of that and insert a new T valve.
Brilliant. Thanks. I've got a Y piece arrivig today and can will nip to Screwfix for the McAlpine double. (I realsed my inital post & pictures were unclear and that the fact there was a washing machine already connected wasn't obvious)
