Support for lights
Because we're a practical lot usually and when someone just drops a 'computer says no' response we like to delve deeper.
What about some 18mm plywood cut into 6" strips, then joined together to make a long enough length to follow the curve of the roof/walls. Once you had several of those, you could then knit them together with some lengths of floor boards or similar, set at the height you require your light to be at.
Can’t touch the roof. What don’t you understand about this limitation?
It's hard to understand the reasoning behind it, given that the alternative throws up more problems than the ones you are trying to avoid.
FFS what don’t you understand.
Been told NOT to touch the roof and hence the thread for alternative recommendations
I still wouldn't rule out catenary lights completely, there are some good looking ones about nowadays.
Add some ww2 search lights in the corner, it would be nice and bright then :)
So without affecting the structure, build some thick wooden freestanding frames one at each end in the middle.
Then between them both you want a 7m pole - like a stair bannister or scaffold pole, from this add your lightweight lights.
May require a middle support.
Or use them new fangled wifi powered lights that use skyhooks :)
