Swivel sanding block
5 Apr 2011
Hampshire
As above do these actually work, got a ceiling to paint and just wondering weather to buy one to use on a pole or just stick to a normal sanding block. Thanks
Very useful on a decorators variable length pole. Really speeds up the process
They work but it takes a while to get used to them. Ideally you will be sanding a couple of metres away from where you are standing so that the dust doesn't land on you.
