Bus driver sacked OMG
As I said, get a grown up to read it.
here is page 4 Just so that everyone can see what a liar you are:
here is page 4 Just so that everyone can what a liar you are:
Yes that's the page. I have posted the link 26 times. The snippet is under the heading "what if I chase them after they have run off". It is quite clear and succinct. I haven't altered their words.
Here are the rest of the facts that tally with the CPS stuff, some of it as you know I posted prior..
The Criminal Law Act 1967 does not give you a blanket right to chase a fleeing suspect with a weapon. While Section 3 of the Act allows for the use of "reasonable force" to prevent crime or make a lawful arrest, using a weapon against a fleeing person is extremely likely to be deemed disproportionate, excessive, and illegal.
The Legal Position (Criminal Law Act 1967)
  • Reasonable Force Only: Section 3(1) states: "A person may use such force as is reasonable in the circumstances in the prevention of crime, or in effecting or assisting in the lawful arrest of offenders or suspected offenders...".
  • Proportionality is Key: The force used must match the threat. If a suspect is running away, they are generally not an immediate threat to you or others. Chasing them with a weapon implies a desire to harm or punish (revenge), rather than to stop a crime.
  • Grossly Disproportionate Force: If you chase a suspect and use a weapon—especially if you cause serious injury—it will almost certainly be considered "grossly disproportionate," and you may face criminal charges, including wounding or assault, regardless of the fact that they stole from you.
What if I chase them as they run off?
This situation is different as you are no longer acting in self-defence and so the same degree of force may not be reasonable. However, you are still allowed to use reasonable force to recover your property and make a citizen's arrest. You should consider your own safety and, for example, whether the police have been called. A rugby tackle or a single blow would probably be reasonable. Acting out of malice and revenge with the intent of inflicting punishment through injury or death would not.
Chasing a fleeing suspect with a weapon and subsequently using it is highly likely to be considered malice, revenge, or retaliation rather than self-defence in legal terms, particularly if the initial threat has passed.
(Source - CPS)
(y)
you have claimed this:
(Source - CPS)
(y)
is source from page 4 of this https://researchbriefings.files.parliament.uk/documents/SN02959/SN02959.pdf
Its a complete lie.
Its a complete lie.
Take it up the the CPS. I care not
In case you missed the rest of the facts...
(Source - CPS)
(y)
as expected
(Source - CPS)
(y)
The facts are not going to change boyo, no matter how much you sulk.
The context is clear
#46 #47 #49 #51 #52
we were only ever discussing s3(1). all the discussions about the common law right to use reasonable force was, as has been said many times the wrong law.
But seriously, they are talking about slightly different things. So, they are both right.
I've not claimed anything different. MBK has tried to throw in all kinds of deflective waffle, in an attempt to bolster his argument. I have been succinct from the outset and in continuation from a previous thread.
I said that - to go on chasing (pursuing) and attacking suspect, once the threat is over, with a weapon - is not lawful. No mention of recovering goods. No mention of pursuing in the name of arrest. No mention of further threats of violence from the suspect.
Cut and dried right here....
(Source - CPS)
(y)
He can waffle and deflect all he likes.
I said that - to go on chasing (pursuing) and attacking suspect, once the threat is over, with a weapon - is not lawful. No mention of recovering goods. No mention of perusing in the name of arrest. No mention of further threats of violence from the suspect.
I agree that if you chase someone with a weapon, with no intention of arresting them, but purely to mete out punsihment, then that is unlawful.
Give it up boyo.
(Source - CPS)
(y)
stop coaching him..
He's referred to section 3(1). which is:
Use of force in making arrest, etc - (1)A person may use such force as is reasonable in the circumstances in the prevention of crime, or in effecting or assisting in the lawful arrest of offenders or suspected offenders or of persons unlawfully at large.
That's the crux of it yes. I think it was ellal that mentioned something to that effect in the fist thread. That's when I picked it up. And when chicken biker came stomping in with his waffle, lies, blarney, deflection and blather.
It's sad. Every single thread he has to ruin.
It's all here...
(Source - CPS)
(y)
not true. It is the same law that allows police to use a baton.
Police cannot immediately resort to the use of a baton, unless other forms of restraint have failed, or there is an immediate threat from the suspect.
And even then indiscriminate use of the baton could result in assault charges, e.g. striking the head or other vulnerable parts.
A piece of scaffolding grabbed in the heat of the moment to lawful pursue a criminal a is none of those things, even if the scaffolding is used on the person while they are running away.
If the act of attempted theft has been averted and the suspect is fleeing, with no sign of violence towards the pursuer, there would be no grounds for further pursuit with a weapon, with an intent to inflict serious injury.
