- Joined
- 27 Jan 2008
- Messages
- 28,446
- Reaction score
- 3,457
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I note at work we do have a one pipe system, steam goes in one end, and water dribbles out the other end, there is no return, but somehow I can't see that is what people call a one pipe system, does not matter if in series or parallel you need two pipes to every radiator, but I notice some radiators have four pipes, two for heating and two for cooling, so is no cooling, what is meant?
I have only seen one house with a one pipe system, the works engineer had connected his house to the works' boiler, so his heating had a steam inlet, in fact only house I have ever seen heated from a boiler, all the rest the water did not boil, so clearly not a boiler.
But I see the phrase one pipe system, I am sure not connected to steam line, so what is it?
