Probably a friend of a "1 gig" somethingAnd what's a 16 am?
A quick google suggests 16A standalone RCDs (not RCBOs) in din-rail format do exist.What else could it possibly be. I don't think anyone is going to find a 16A RCD, in a domestic CU or anywhere else.
RCD or RCCB is technically incorrect. An RCCB is a type of RCD. An RCBO is also a type of RCD.There are at least two things to think about here.
Firstly, what exactly do you mean by "RCB"? that's not a commonly used acronym! To comply with current standards, your socket circuit needs both overcurrent protection and RCD protection.
* A "MCB" provides overcurrent protection.
* A "RCD" or "RCCB" provides RCD protection
* A "RCBO" provides both.
You need to understand what the devices you are looking at actually do and how they are connected. Post photos and ask if you are unsure.
Secondly you need to think about what the sockets will be used for. BS7671 does not explicitly limit the number of sockets on a circuit, but you should not design installations you anticipate will be overloaded.
Denmans were selling them decades ago. Don't know if they still do.A quick google suggests 16A standalone RCDs (not RCBOs) in din-rail format do exist.
Interesting.A quick google suggests 16A standalone RCDs (not RCBOs) in din-rail format do exist.
I'm not at all sure that an RCD has an "In", does it - and, as I said, if (as I am assume) it relates to the maxi,um current it is 'rated' to be able to carry, I doubt that it would be very easy to design one that couldn't cope with more than 16A (and why would one try to make one, anyway?).As in In I reckon John rather than I delta n, it does confuse some people who calls themselves Electricians but that is another story for another day methinks![]()
Not really, just a matter of making things smaller/thinner.I would imagine that it would be quite hard to design one with such a low capability even if one wanted to![]()
In the UK caravan parks, caravans, marinas and maybe some industrial scenarios spring to mind.(and why would one try to make one, anyway?).
I suppose so, but probably only commercially worthwhile if there is a substantial market (which I would not really have expected) - particularly given that 63A/80A/100A RCCBs are no longer particularly expensive.Not really, just a matter of making things smaller/thinner.
