One circuit 2 switches?
22 Nov 2009
Oldham
I've got a 4 gang switch but only 3 circuits (I couldn't find a double 3 gang that came close to matching all the others.
Is it possible to link 2 switches so that at least all 4 switches do something? I suspect not?
Al circuits are 2 way switched if it matters.
Otherwise - leave one doing nothing?
Some confusion in terms, but -
Wouldn't a double 3 gang be 6 gang?
Technically probably all the one circuit.
Yes, but what do you want the extra one to do?
Not really.
Fit another light somewhere.
Thanks. Hopefully the picture of the switch in question will supplement my poor terminology.
No additional lights needed.
I want the second left switch to operate the same light as the first left so it doesn't matter which you press - just because it'll annoy me if it does nothing.
I suppose I could just super glue the rockers together.
Trying to use what I've got. With hindsight I should have got two switches and one of these-
You would need to change a module to an intermediate for what you want to work. Frankly it would be a daft thing to do.
That looks like Scholmore Click stuff, if so it's possible to replace one of the switches with a blank, or possiblly to transfer all the switches to a 3-module plate (though personally I think the 3 module plates for double boxes look a bit weird).
IF you can tell us the part number of the switch, I can figure out which the correct parts are to match.
Thanks. It does look extremely similar to scolmore but there's no branding on it - I wonder if it's a copy/made under license type thing.
Only part number is sw31022.3
Looks like they sell a double width switch that certainly looks like a swap.
Looking back at your first picture, I see a logo in the middle of the switch modules, I think it says scholmore in curved text, but I can't be 100% sure.
It does look very likely but, as you say, one can't be certain. However, I would imagine that it would be easy to read for someone actually looking at the switch ...
