Plumber explains what radiator numbers really mean and why you should 'leave it' at 3
Pardon, are you sure? I thought the T in TRV stands for thermostatic?
What's in a name? I repeat - a normal TRV fitted radiator, limits or restricts the temperature in the room. A room thermostat, is there to call for heat, when the temperature falls too low. As such, the two cannot work effectively if co-located, in the same heated space.
A thermostat or sensor
will cause something to happen when it reaches a set temperature, it does not matter what it does it could cause water to flow, or a valve to open/close, or a boiler to fire, it is still a thermostat.
they are all thermostats. And today there are so many ways to thermostatically control a room temperature, you do need to qualify what you are talking about, I do not I admit I do not cover all bases when I call it a wall thermostat, as I know mine can also be used freestanding, and it can both connect direct to the hub, or to a TRV head, and the first two shown are designed to connect to a TRV head.
If one does not specify what type. Then one has to expect people to ignore it, as it does not make sense.
Correct Eric, but the point you seem oblivious of, is that the room stat switches on when it gets cold, the TRV switches off when it gets too warm in the room.
I can see the room stat switches on when it gets cold, and the TRV switches down when it gets too warm in the room. There is a big difference between on/off and up/down.
The problem is if one stays on, after the TRV has closed. This is the
'fighting', to be in charge of the heating,
Harry talks about.
We need to look at the circulation, the TRV is naturally colder than the Wall Thermostat WT, so if both set to same temperature the WT will turn off before the TRV fully closes. Specially since TRV is often against an outside wall and the wall thermostat needs to be on an inside wall.
There are clearly times when this will not work, due to the room selected, I have never worked out, how the hall can be used as a sample room, as to place the wall thermostat on the opposite wall to the radiator and TRV and to get the flow of air with a staircase coming off the area is near impossible, so to fit a TRV and wall thermostat in the hall, is going to present a lot of problems trying to set it up, so Harry's statement likely true in that case.
The point is still going straight over your head.....
For the room stat to click off, the room temperature has to exceed it's set point, which means the TRV has to be set higher than the stat. IF the TRV is set higher, then the temperature will be controlled by the stat, the TRV cannot operate to ever close, and it therefore it has no purpose in life.
Why not? It is as representative as anywhere else in the house. The installer, decades ago, designed and wired it to be in the living room, I insisted, it should go in the hall, because when the gas fire was lit, the CH would go off, leaving the rest of the place cold. I now have two wired stat positions blanked off, and a wireless stat running the system.
The stat is set to 18C, which is the temperature in the hall, other rooms, are warmer, their temperatures set by their individual TRV's, and all just works, sweet as a nut, with boiler only rarely firing.
I have a simple FantiniCosmi digital roomstat in a combined (two rooms) dining and living room with two rads and where we spend 99% of the time, the heating is switched on at 0700hrs and switched off at 0100hrs each day, roomstat set to 19.5C during the day and 20.5C (sometimes 21C), from around 1800 hrs, all other rooms have mechanical TRVs set to give a temperature around 18C, all TRVs installed horizontally on the return to give a more representative air temperature. The roomstat is set to its minimum differential (hysteresis?) of 0.3C, but a bit strangely, once up to temperature and while it switches off as expected at the setpoint temperature, it definitely switches back in very shortly after the temperature falls by 0.1C and certainly before it falls by 0.2C, (does not have a TPI function), works perfectly well, on startup in the morning, with a roomtemp of 16C to 18C, depending on tht OAT, it overshoots by 0.3C/0.5C but after another one or two cycles, by only 0.1C/0.2C, invariably, anytime you glance at it in passing, its spot on at its setpoint temperature. So the other rooms take what they can get up to a max of 18C ish, works fine for me with minimal controls.
