- Joined
- 3 Sep 2024
- Messages
- 24
- Reaction score
- 1
- Country
Hiya, I was doing some work in my kitchen and behind a cabinet was the air brick below.
(small semi detached cavity wall house from 40s/50s)
Q1) in the pic below, the cavity surrounding the air brick appears to have been intentionally closed on all sides - forming a sort of air tunnel into the kitchen -
I assume this was done to ventilate the room?
This property used to have a gas fire and back boiler downstairs.
Q2) this air tunnel is, I assume, creating a good bridge between inner and outer skins, increasing moisture in the inner skin etc...
Should I get rid of tunnel, separating the inner and outer skins of brick work? (My gut feeling is yes, I was wondering if I had overlooked something)
Q3) is it normal for the cavity to be full of rubble?
Will
Will
