- Joined
- 26 Jul 2015
- Messages
- 370
- Reaction score
- 10
- Country
I have a bath filler and im really not sure its going to be decent enough pressure for filling a bath.
Its a scudo with valve. Lots of other oems using this design as well if it helps.
https://www.britishbathroomcompany....CAiD42nNu452Mj9p0VrKjbyW-sjHXt5N0mHOlFlQrE3d8
The pressure is slow and very poor on the cold feed with cold on 22mm dropped to a 15mm run with pegler isolator and then into a 3/4 15mm tap connector.
My gut here is the valve then has these on the connector with 8mm bore.
Am i on a hiding to nothing with this valve?
