soldering AAA batteries
1G you just got the whole lane to yourself; no one else could transmit/drive if you were using it. Some radio use still works this way; aircraft traffic, FM radio.. You can’t have two users on the same frequency at the same time
Like going from a foot path to a dirt track then to a C, a B then an A road then a Motorway I guess!
If 12G is still going, why did all the remote monitoring systems for the water companies fail a few years ago and suddenly thousands of new devices had to be sourced very rapidly?
There is no 2G on either of the 2 sites I have kit on and both are very prominent sites.
So what happened to the 1G ad 2G towers then? are they sill there or take down?
Er, it wasn’t quite what I was going for. The example was always that the road (radio waves) stays the same, and it is how it is used that gets cleverer and cleverer. Radio waves haven’t changed since the start of the universe, they just wiggle along, travelling some distance, passing through objects etc
We haven’t made them faster or wider or mode of harder, shinier stuff
We’ve progressively and massively improved the things we send along them
No point taking a tower down when you can bolt a newer antenna to it. I presume you mean the service. Some it makes sense to phase out, others it makes sense to keep. There are still millions of FM radios despite DAB being a thing. Analog TV broadcasting is gone however
So you are saying that you can still send a 1-5G down the same signal path
Where the masks taken down or still remaie?
G-ness isn’t much to do with radio waves. Radio waves are the road; they don’t really change or advance, they’re just a way of getting info from one place to another
I don't disagree with any of what you have written, but I thought muckington was asking whether the frequency of the radio waves has changed during the passage from G1 to G5, wasn't he/she? - a that's a question to which I personally don't know the answer (although I suspect it is "no") without doing some reading.
In very broad brushstrokes started at 800/900MHz and basically spread up and down ever since.
Changed by addition, sure. 5G uses additional frequencies that 2G doesn’t, but I really want to get away from associating the two. Successive generations achieve better performance not primarily by using other frequencies..
You can’t escape the physics of the universe, that low frequencies travel far but don’t pack as much info and high ones vice versa on both factors. Classically I always felt it was a bit of a con, for Orange/T to sing about how many more masts they had than Voda/O2 - Orange masts were greater in number because they had to be; the 1800MHz signals don’t propagate as far so more masts are needed for coverage
They are essentially, the very same transmitters, as used to be used for 625 UHF transmissions, where we had 2, 3, 4 channels - now we have what - adapted to150 TV, 30 radio digital channels?
Changed by addition, sure. 5G uses additional frequencies that 2G doesn’t ..., but I really want to get away from associating the two. Successive generations achieve better performance not primarily by using other frequencies..
OK, but I'm still a bit confused about the relationship between 'Generation' and frequency. As far as I can make out, some 2G used/uses 1.8 GHz, as does a lot of 4G also uses 1.8 GHz, with the highest frequency used by 4G only being modestly higher at 2.6 GHz - this all suggesting that there is not a very clear relation with the progression of 'Generations' and frequency.
Indeed, and, as I'm sure you know, it's not just a question 'how far', but also how far it can travel 'through what'. Although they can carry more data, the higher frequencies are less able to penetrate or 'go through' building/structures etc. and therefore presumably require much higher 'density of masts' than is the case in more rural environments.
One thing I have yet to understand is what this all means in terms of the phones. For each 'G' one sees a range of frequencies mentioned. Does this mean that phones have to be able to switch between, and use, different frequencies according to 'what they find', or what?
As I keep saying, there isn’t a direct relationship between generation and frequency. A mobile “generation” is mainly about the radio technology and network architecture: how the spectrum is used, how data is encoded, how devices are scheduled, how antennas are used, how handover works, latency, efficiency, and so on.
The frequency spectrum is divided into bands, and in the UK licences for mobile spectrum are issued by Ofcom. Those licences are valuable, so once an operator has spectrum it wants to use it as efficiently as possible. Moving from 2G to 3G to 4G to 5G generally means using the same scarce radio resource more cleverly, not simply “using a higher frequency.” Ofcom lists UK mobile/wireless broadband spectrum across bands such as 700 MHz, 800 MHz, 900 MHz, 1400 MHz, 1800 MHz, 2100 MHz, 2300 MHz, 2600 MHz, 3.4–3.8 GHz, and 3.8–4.2 GHz.
5G can use multiple kinds of spectrum. In the UK, 700 MHz is useful for wider-area coverage, 3.4–3.8 GHz is a key mid-band range for higher-capacity 5G, and very high bands such as 26 GHz are aimed more at dense/hotspot use where short range is acceptable in exchange for very high capacity. Ofcom awarded 700 MHz and 3.6–3.8 GHz spectrum for services including 5G.
2G in the UK has historically used bands such as 900 MHz and 1800 MHz. Those frequencies are not “2G frequencies” in any permanent sense; they are just licensed spectrum that happened to be used for 2G. Operators can refarm spectrum: switching off older technologies and reusing the same frequency range for 4G or 5G, which can deliver much more capacity from the same airwaves.
So, yes, 5G often uses more and sometimes higher frequency ranges than 2G did. But the performance improvement from 2G to 5G is not mainly because “the frequency went up.” It is mostly because the technology using the frequency became much more efficient, and because operators may also have more total bandwidth available.
That said, the physics still matters. Lower frequencies usually travel farther and penetrate buildings better, which is why bands around 700/800/900 MHz are valuable for broad coverage. Higher frequencies usually have shorter range and poorer penetration, but there is often much more bandwidth available, which makes them useful for high-capacity urban or hotspot deployments.
In the UK, 2G will not continue indefinitely: operators have told Government they do not intend to offer 2G and 3G past 2033, and Ofcom says individual operators may switch off earlier.
Yes — broadly, phones do switch between different frequencies, but not by randomly scanning and using whatever they find. That implies the phone is like some sort of passive FM radio that knows how to jump from 88.1MHz to 90.5 MHz to keep listening to radio 2 when the signal strength on 88.1 degrades; management of cell networks is incredibly more active than that and a true engineering marvel
A phone is built to support a set of frequency bands and radio technologies: for example GSM/2G, LTE/4G, NR/5G, depending on the model. The mobile network also broadcasts information telling phones which cells and bands are available nearby. The phone measures signal quality, reports it to the network, and the network normally decides when the phone should move to another cell, another frequency, or another technology.
Each “G” can operate on several possible frequency bands. A phone must support the relevant bands, and the network must be licensed and configured to use them. The phone does not just choose any frequency; it camps on and hands over between authorised network cells.
For example, a phone might use:
700/800/900 MHz for broader coverage, especially rural or indoor coverage;
1800/2100/2600 MHz for more urban capacity;
3.4–3.8 GHz for high-capacity 5G;
and possibly mmWave in some countries or dense hotspot deployments.
Thus, phones are designed to work across multiple frequency bands, and they can switch between them. But they do not simply hunt around the spectrum and use whatever they find. The network broadcasts information about available cells and frequencies, and the phone measures signal strength and quality. The network then usually instructs the phone to use a particular cell, band, or technology.
This is why phone specifications list lots of bands: a given model has hardware support for some set of 2G/3G/4G/5G bands, but it can only use bands that both the phone and the operator support in that country.
So when people say “2G uses these frequencies” or “5G uses those frequencies,” they mean those technologies can be deployed on those licensed bands. In real use, the phone may move between different frequencies as you move around, as capacity changes, or as the network steers it between coverage and speed.
Modern phones can sometimes use several frequencies at the same time. With 4G this is called carrier aggregation, and with 5G there are similar mechanisms, including using 4G and 5G together in some deployments. So it is not always just “switching”; sometimes it is combining multiple carriers to increase speed.
As I implied, that's how it seems from what I've been reading. I've come across these lists/tabulations which I think roughly describe the current situation of mobile phone bands as licensed by Ofcom (and which is broadly consistent with what you go on to write) ...
I, for one, have certainly never suggested that such was the case. In fact, as we both have said, in relation to some aspects of 'performance' (e.g. greater 'coverage', particularly in built-up areas) lower frequencies are superior. In some senses, this is not a totally unfamiliar concept - if I wanted to establish inter-continental radio communication (other than via satellites etc.!), I certainly would not think of using VHF, let alone UHF :-)
Yes — broadly, phones do switch between different frequencies, .....
As you probably realise, I was imply that such was what I had come to presume.
but not by randomly scanning and using whatever they find. .... A phone is built to support a set of frequency bands and radio technologies: for example GSM/2G, LTE/4G, NR/5G, depending on the model. The mobile network also broadcasts information telling phones which cells and bands are available nearby. The phone measures signal quality, reports it to the network, and the network normally decides when the phone should move to another cell, another frequency, or another technology. .... Each “G” can operate on several possible frequency bands. A phone must support the relevant bands, and the network must be licensed and configured to use them.
It sounds pretty complex/'clever'. I would certainly not use 'intelligence' to describe the behaviour of the phones or networks (everything done by computers seems to be called "AI" these days!), but there must be some pretty clever algorithms (created by human beings) involved!
That sounds particularly complicated! Are you suggesting that two or more frequencies can be used simultaneously to transfer a single data stream? If so, I'd be intrigued to learn how that would be achieved!
The one thing that rather amazes me is that reliable communication can be achieved at the sort of frequencies we're talking about (even 800 MHs, let alone higher) with the phone having (presumably) very low power and only a tint approximation to an aerial/antenna. Even at the mast end, although much higher power is presumably possible, the aerial/antenna is still a problem - with point-to-point radio communication at such frequencies, one normally uses aerials/antennae with high gain achieved by their being very directional - something obviously totally inappropriate for mobile phone communications. ...
.... more decades ago than I care to remember, when I was playing with communication using the 23cm (1,296 MHz) amateur radio band, we struggled to get reliable communication over decent distances, despite relatively high powered transmitters and high gain aerials/antenna (usually fairly substantial dishes or complex arrays of yagis). This photo shows one of the dishes I was using for 23cm in the late 60s (photo with people shown, to give an indicator of size). As above, that dish was highly directional (hence pretty high gain), which would be impossible for mobile phone communications.
...That sounds particularly complicated! Are you suggesting that two or more frequencies can be used simultaneously to transfer a single data stream? If so, I'd be intrigued to learn how that would be achieved!...
Simplest is to use a wider band width, ie use several adjacent channels.
And yes the phones do change frequency, rather like a trunked radio system where the phone sits on a control channel then when making or receiving a call handshaking will negotiate a free or otherwise available channel.
In fact that's the twiddly dum twiddly dum twiddly dum we hear breaking through onto audio systems (So I'm told) which runs at highest power available (often 4 or 2 W) and negotiates to the highest power required for adequate comms which is often way down to low mW or even μW.
As I understood it, multiple calls can actually share the same channel, at the same time, using store and reassemble the calls.
During the house arrests of the sprig of 2020 was the same time that the 5G satalights where being switched on. It was noted that the change of frequency in the ionosphere was making people sick! it was also noted that 5G was 60ghz, the same frequency as the oxygen molecule in the blood renderig them usuless and hence causing respretra breathing problems
Please go away.
