Missing bricks under chimney stack
8 May 2026
Hey guys. Digging out part of my patio and noticed under the chimney there is a void which is just soil. Is this normal? Should I be concerned? Does it need digging out and backfilling or am I best just leaving it?
Any advise or other experiences of this welcome. Mantle of bricks is about a foot under patio level. Thanks in advance.
If you dig a bit deeper I think you'll the bricks corbel out from the main foundation
Ash dump hole maybe.
I've got this foggy memory of holes at the back of chimney to aid in cleaning it out.
Maybe that?
If you've scraped that soil out for no reason, best stop, refill the hole with concrete and then finish what you are doing around the walls.
You may have undermined the house! Older houses didn't always have a 'proper' foundation.
Those bricks which are 'edge-on' are part of the foundation to the chimney, so your hole is actually a void you've dug under the foundation.
The casualness of it might surprise you, but the ground looks to be sandy and probably of reasonable bearing capacity; the builders of old would have known what they were doing. The house is still there after (120?) years.
Backfill it with weak-mix concrete rammed well-in, and in future perhaps avoid the temptation to dig holes under your walls!
Thanks all. Lots to think about! Didn't consider that it could be foundations as there is a cellar below the house.
