Hell fire I didn't expect this.
Have we ever had a power flush? Yes. Can't remember when though. I'll say maybe 6 years ago?
Just to double check, the plumber was clanging & banging all the radiators. Sound like a power flush? After all this job he then installed a Magnaclean filter.
I did wonder about the corrosion in the first phot as to whether that's normal or not.
I don't know of any noticeable leak on that TRV although there are one or two rads which have that green crud around them which I think it supposed to be leakage? Again not massively so. I'll have a see tomorrow & come back here.
Regards the
unscrewing as mentioned here, is it just a case of get an adjustable spanner & undo or what?
Reason I ask is when you scroll around videos & come across plumbing videos, the comments are always full of contradicting do this, don't do that & nobody agreeing on how it should be done.
Bit like this post here I suppose.
Am I supposed to hold the lower part tight while undoing that collar or should it be fine to just remove as I said with a pair of adjustables?
