Steps, cement or not, and what to put under them.
27 Jan 2008
Llanfair Caereinion, Nr Welshpool
The drive is steep, and the garage turned into a flat, so set about turning the first couple of yards into a patio, gardener had a heart attack, had to DIY, and load of building up required, so used ash from local steam trains, which seems to have worked well.
So now knocked down shed, and need to make some better steps. So fitting them 1780270214809.png in front of the concrete wall to right, old steps centre too steep. Since sleepers already used, 1780270401975.png the old shed base has been reduced in size and a wall of three sleepers used. Sorry too dark for new pictures.
So what I am not sure about is if I can use ash again under the steps, as there is a massive void needing filling, first step will have cement under it, to level it, but after first step it will need a lot of fill. And ash is free.
Cats can sleep anywhere - he/she looks real comfy. :cool:
You could mix the ash into cement, no?
When I moved into my property they had used old pallets with concrete blocks under and then paving slabs on the top. This could only be a temporary solution. I built the 3-sides of the 1st step using concrete blocks and then filled the inside with rubble and a layer of concrete and then built the other steps in layers.
Rain has stopped play, top rail just sitting there, as may be too high, want steps first. Need to clean off bricks, and building rubbish will fill up some, but think ash like under the right patio is a likely way I will go.
1781020956778.png1781021003870.png Unfortunately the local builder merchants has run out of slabs the colour I am using, and the ash will settle a bit so need to leave for a bit to settle, however you can see old to left and new steps, and to look right, think I will need to cement the bricks as with second step simply to look right.
So now done, except for handrails. Not cemented yet, going to allow it to settle first, then where needed to use cement.
Still need to consider handrails, I have no idea what is behind the cement rendering, and how strong any handrail will be if using raw plugs I attach to the rendering, seen in this 1781515834170.png photo to the right of temporary steps. Better nothing to something which may fail. I want something to stop any chair used slipping over the edge, before there was a shed, where the steps now are, at a lower level to patio, so that stopped anything or anyone going over the edge. So ideas welcome.
1781695021527.png So still looking at the sleeper wall, needs a box of some sort to hold enough soil to support plants to hide the wall. I looked at this 1781698879998.png and realised the top has a membrane to hold the water, so maybe better with something like this 1781699245502.pngbut gardening is not my thing, so looking for ideas.
That is the sort of thing I am looking at, but what to plant, and how much soil is required etc.
6" of soil is enough to plant some bamboo which comes in a variety of sizes to suit, and being captive won't run away in the garden [it grows rapidly.]
