My DIY Shed
I built mine out of 4 -- 7f x 6'6 garage doors bolted together, cut out for a door on one. A triangle section bolted on the each end, a 2x2 timber on top to connect both triangles forming an apex roof - 2 sheets of 8x4 OSB covered with felt -- later covered with tar impregnated corrugated sheets as well. So its a galvanised steel 7x7 shed for hardy any money - the garage doors came free when people were replacing with roller doors..
I picked up a cheap UPVC front door that was old and damaged but perfect for a shed.
I have made some more progress. I have got the framing done and the walls up. I ended up cladding this in OSB. At a later stage I'm going to add cladding. Video uploaded:
Next step is the roof.
Progress looks good so far. Excited to see how it turns out!
I just put a video together for the roof. Cam out great. I went for a pitched roof so had to do birdsmouth cuts. I wasn't looking forward to those but they went well. I'm also capturing the build in a Blog but that's a bit behind the videos. The shed has come out a bit too well, so not sure whether make it I to a garden bar. Still got time to think about it before I tackle the inside.
I finished the roof. Did it will artificial slate. Turned out well.
