Fixing wooden board to tiles
Do you know what a munsen ring extender is?
I do as I looked up what a munsen ring is.
As I said a support of this sort would have cost more, not matched the pipe of or the existing bracket, and probably not have worked unless it matched the pipe diameter by chance.
Easy job , white spacer would match you almost white walls .You mention atheistics while proposing an abortion of a solution .
So a white spacer matching the white walls is good but a white board matching the white walls is bad. How is that?
And you were the one mentioned aesthetics, "Just use 10-15mm spacers behind brackets neater than a board".
Best ignore it then and just shove a slab of manky old plywood on the wall as you obviously intended to do all along.
I really don't like to be rude but your ignorance is matched by your arrogance. You have made up the "slab of manky old plywood" crack out of whole cloth.
And I described your idea of throwing away a perfectly good fitting to buying & installing a non-matching one (that may well not work) as ridiculous because it is. The fact that you did not dispute my comment but responded with unfounded abuse says a lot about you.
I'm quite impressed at the level of entitlement, rudeness and ignorance displayed by the OP towards a number of people who have offered sound advice out of the goodness of their hearts and the benefit of their experience.
Don't bother replying, unless it's an apology towards the community - your rudeness towards others trying to help you is breathtaking - I imagine a number of others will be, as I am, just hitting the ignore button right now.
(If anyone else chooses not to ignore and there is an apology - do let me know)
Cheers, Stephen
Just gob the gap up with a load of clear silicone, you can shape it to bracket profile and when it dries it will be invisible, a bit like magic, locking the pipe in place.
That will look neater than bit of s'crappy old board.
@StephenStephen
And I am quite impressed at the level of rudeness displayed by some of the commentators. Of course I am not talking about @Wayners and @^woody^ who offered helpful advice which I clearly said (post #6) I had followed.
"the OP towards a number of people who have offered sound advice"
Exactly how is suggesting throwing away a functional and matching bracket then buying and fitting a non-matching one "sound advice"?
And how is describing something they have not seen as "a slab of manky old plywood" "sound advice"?
You, and others, have been critical of my comments but have made no effort to explain how they are incorrect. On that basis I can see nothing whatsoever to apologise for.
Would bending the wings in help you to gain the required depth?
@opps Thanks for the suggestion. I think it is too far off the wall for that to have worked, but I can't be sure as it is fixed now. Once I had gained confidence in drilling tiles I was able to fix a (white gloss painted) board of the right depth to the wall.
