What’s this in my Shower head filter?
4 Dec 2019
Ok , so I was changing my showerhead and noticed this small spring and nut stuck in the filter. I assume it’s some kind of internal valve that has come apart.
As you can see it’s a mixer shower with a rain fall and hose shower. We only use the rain fall shower so maybe from the hose shower. (Note) we noticed that the temperature can’t be changed as it always come out hot. Easy fix or full replacement?
Looks like the wax capsule which is part of the temperature control, shouldn't be too hard to swap if you can find the correct one.
