joining 10mm copper pipe to 15mm copper pipe
14 Oct 2007
Lancashire
:eek: hi im having a problem.im fitting a new bbathroom and everything is going good except the radiator.the old pipes are 10mm and im trying to change them to 15mm togo on new radiator .ive done 1 side but the other just wont join. ive used a coupier?? but i cant get it to seal.ive used flux and soilder but it still leaks HELP ME!!!!! :cry:
did you clean the pipes with steel wool first and the pipes must be empty. you must also use flux
yeah wire wooled both sides and waters been off for a week and drained.sick of going to mums for a shower
