Will 10mm to 15mm cause trapped air?
18 Oct 2005
Staffordshire
I am fitting extra radiators and using a mixture of 10mm micro bore and 15mm copper pipe. When fitting 10mm to 15mm copper pipe in a central heating system, is it true that you can only reduce in size and not the other way, as it will cause trapped air.
