0.4 Bar reading on boiler / Not working
23 Jan 2007
Hello. My boiler at home has been playing up the last few days giving me an error code F.22. Looking through my manual it says it needs topping up as it's dry. My pressure should not drop below 0.5 bar and mine is showing 0.4 bar. I have a loop pipe on my system for the water but turning either one is not doing nothing. It's been very cold these past few days and I would love to get his working again. Thanks for any info. Mark
This is my boiler...
The boiler is correctly diagnosing the water pressure is too low.
You should already know how to top it up to 1.5 Bar with the filling loop we can see in the nice clear pictures.
I cannot see exactly which type you have but if you are really opening the valve then the loop or non return valve may be blocked or jammed and will need replacing by somebody who knows what he is doing.
Tony
Thanks Tony for the reply. My boiler is a Vaillant Eco Tec Pro. I have called someone out and he will be here this afternoon. Cheers
Do you have TWO black plastic valve handles and are you opening BOTH of them at the same time?
This boiler is not very old and the installer should have shown you how to refill it.
Tony
