1.1 Peugeot 206 (1999) dashboard , heater matrix
30 Aug 2010
Wellnow
before i state what im looking for help with i want to comfirm to see if im right .....!!!!!!
on the passenger side floor the floor is wet and i assume its the heater matrix ,as these no leaks, and the head gasket is gone too, if im assuming right
i need to know whats the easyiest way to replace it ..... cus the dashboard seems realy hard to remove .......or an easy step by step dashremoval or a easy replacement trick, if some one could shead some light please help
can you elaborate a bit more as the description is vague
Are you losing engine coolant and is the engine overheating at all?
To confirm that it is coolant dip your finger in it and taste it, antifreeze will be sweet.
Peter
if you look up in the foot well on the passenger side theres a section thats leaking coolant and its part of the heating system ................ and the car isnt over heating or using too much water .............
