Peugeot 206 rear FOG light
30 Aug 2010
hi all and thanks .......
right i bought this 206 weeks ago nd the rear fog light didnt work
it was disconected so i connected it all back up still nothing
the bulb is fine !!!!
and fuse seems to be fine !!!!!
and at the moment i have no circit tester :( .... so there no way for me to see if current getting there
at the moment i dont think there front fog lights if some one cold tell me that too it would be much apreciated too
so if anyone has any clues dont be afraid to shout out cus once again im stuck
Peugeot 206 , 1.1litre , 1999
:eek:
Remember, your rear fog lamp has a 2 wire connection....one is 12v power in and the other returns to the bodyshell somewhere as an earth.
Make sure you have a single filiament 21w bulb with clean contacts, and likewise with the bulb holder. Waggle the bulb around with the lamp switch on (not forgetting, you need the main lights on for this).
If no joy, check the connections, and then off to Halfords for a cheap tester. As the lamp was disconnected, the fault may be up the electrical loom somewhere....
regarding the front fog lights.....do you mean they don't work either, or you don't know if you have any?
John :)
ok ill give that a try on mondays when the effect of drink is gone
and the front fog light is a confusing cus the book said they are there and the bulbs arnt where the book said :confused:
is it a usal ocourance for a switch to go one the stalk
cus thats where im thinking the problem lies
but i trying ur idear first cus it seems easyer than ripping the inside a part
but if u think of any more things give me a shout
