S
Shutpa
Elsewhere on this forum I said that I had problems getting the degree zero at the top and not the bottom of the number, eg 15o. Empip suggested that while holding down the Alt key, I should key in 0176 and the problem would be solved. However, when this didn't work for me, someone else suggested that the Numbers lock should be on, but still I couldn't get the required result. Now I ackowledge that I really am computer illiterate and that the answer must be really simple, but it is only simple if you know how.
Empip's suggestion:9o, 80
Other suggestion: 9o, 8o
Why didn't I stick to 15 degrees?[/list]
