1" thread shower rose
13 Mar 2006
London
The rose on my shower has died and the pipe diameter is 1". I can't find any replacement roses that are anything other than 1/2" (e.g. http://www.plumbworld.co.uk/315-1821 - which doesn't state it is that but I'm pretty sure it is.
Does such a thing exist as an adaptor that would convert 1" to 1/2" for this purpose? I'm sure it does, I just don't know the name for it so it's proving tricky to find.
Many thanks if you can help.
Is it a 1" bsp male or female thread you are trying to reduce ? If its female you can buy a reducing bush at plumbers merchants to take you down to 1/2" bsp .Which should suit the male thread on your shower head or if female shower head fit a 1/2" x1"" nipple .Hope you understand this.
Thanks for replying.
Ok, on the pipe it's got a male head (ie with thread on the outside) and the shower rose is female (thread on the inside) -
So I want a 1" (female) to 1/2" (male) reducing bush, yes?
Probably what you want or can try is a 1" female to a 15MM Comp straight you should be able to screw the shower on the 15mm end wont look too pretty but heh its better than nothing.What we usally do is canabalise a couple of fittings and silver solder them .
If you can get the 1" down to 1/2" female i can send you this.
It is for shower heads being fully directional on a ball joint.
It's 1/2 male x 1/2" female and all chrome and shiny :wink:
Really kind of you. Thanks.
Think I need to start calling some plumbers merchants...
You can buy 1" shower roses, it just depends on the size of the head and how much you want to pay :roll:
CP Harts of London have them for example, and up to a 600mm rose.
Give Hudson Reed a call as well.
Also try 0845 8386394, local rate
If the pipe is 1" diameter most likley to be 3/4 bsp
fathertobe said:
Can you expand a little on that bobxx?
What are my options?
Assuming existing pipe 1" dia need a 3/4 bsp female to 1/2 bsp male to fit shower head.
