Hi all,
My first post here![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I've been trying to connect up a 1 1/2 bowl sink, but I'm struggling to get the right connections to join it all up into my waste pipe and keep the U-bend higher than the waste outlet.
Here is a picture of the sink in question:
![](//img408.imageshack.us/img408/9489/img0458q.th.jpg)
Is there such a thing that would connect the half bowl on the left into the horizontal connector on the right bowl? Astracast, who made the sink, supply it with a kit to connect the bowls up using the vertical connectors, but it takes up quite a large amount of space and makes it tricky to get connected to the waste outlet. The diameter of the pipes in question is 40mm.
If not, I wondered if something like this might be usable, assuming I could find one with 40mm connectors:
http://www.toolstation.com/shop/Plu...+12+Lengthening+pc++Adaptor/d20/sd3133/p54424
Any help you can give would be appreciated![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Matt
My first post here
![](http://img408.imageshack.us/img408/9489/img0458q.th.jpg)
Matt
