100-150mm width roof sun tunnel?
17 Jan 2015
Hertfordshire
Hi
Does anyone know who manufactures or supplies a sun tunnel / solar tube which is approx 100mm to 150mm in width?
We're trying to light up a small dark area on the first floor and will need approx. 3m of pipe coming from the roof, but I can only find firm supplying e.g. solar tunnels of 250mm in size. We have a width restriction.
Thx.
What's the width restriction-rafters or something more significant?
Or just stick an LED source up there (with a solar panel on the roof to drive it if you want to feel virtuous)- sun tunnels are pricey, payback will be a long way down the road.
No its natural light I'm after as its a small corner of a new hall way we have built with rooms to the front and back. We will have enough LED and artificial light.
The restriction is that if we have a 250mm tube, it will obstruct the door of the room immediately above where the tube is going to come down from. A 100mm tube will comfortably fit behind the door of the loft.
I can't see a 100mm sun tunnel working, sure you'd see a bit of daylight if you looked up it but I would expect any meaningful light to be absorbed by the tube on the way down and for that reason I suspect that's why you can't find one.
They don't exist that small you could try and make up something yourself ie. ss flue liner.
