Just taken delivery of the above for a job, why in heavens name do they have three 40mm knockouts in the gland plate, just had to order a selection of reducers from RS, Grrrr
Knockouts are never the right size/where you want them.
I had to drill a 40mm hole today for a 5c 35mm SWA, it was a proteus 100A fuse though, so 20mm holes!!
I also had to drill some 32mm holes in a 4mod enclosure for stuffing tail glands. There was no space so had to go between two knockouts. One fell in, but thankfully those wiska glands with reducers are so huge you'd never know.
If you use sheet metal punches, then it actually ends up being easier than if the box had no knock-outs to begin with, because you don't even need to drill the centre hole for the punch's bolt! No mess created at all.
