10mm fixing banding to strap waste water pipes
13 Feb 2025
I used All Purpose Fixing Band (12mm wide) to fix up 40mm waste pipe (shower) and 110mm waste pipe (toilet) under floorboards. Access is very very restricted. See attached. Should I replace this banding with proper pipe clips? Originally there were no clips and the 40mm pipe had dropped.
Clips are made of plastic and folk used to use nails, so that will be fine.
