12 V Fan Motor, Which Resistor Do I Need?
Thanks for all the responses. I've managed to find a variable resistor with a more suitable range, 0.1 to 10 ohms, rated for 100 watts so will give that a try. Couldn't belive how hard it is to find such a thing, had to get it from the states in the end.
Why are you doing all this rather than just installing a normal extractor fan, designed to do the job, not be very noisy, etc?
What do you recommend, extractors that I considered were about £100 and didn't look suitable for mounting on thin plywood?
£100? :eek: What was it about those that made you consider them, and what was it about the ones which are a fifth of that (or less) which made you discount them?
And if you can get fans designed to be mounted in a pane of glass, I don't know why plywood would be a problem...
Presumably you've already tried to stop the rain getting in? Spray foam, mastic, flashing... etc?
