- Joined
- 27 Jan 2008
- Messages
- 28,798
- Reaction score
- 3,516
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
Over the years I have had many type inflators, in the main on failing and stripping down, I find very poor quality, the big ends are often a hole drilled in aluminium which has worn oval until a point where it jams. Often only option is to dump it, and buy yet another. Even those which look good quality, with digital displays and ability to set the cut out pressure on failing and stripping have been very poorly made.
So when my Lidi one failed, I thought time for another, but never the less I would have a look, well motor shaft was two roller races, and big end a sealed roller bearing. The brush had stuck no sign of brush holder melting, and on reassembly it is back in use. Not easy to reassemble, but for once a tyre inflator which seems to be well made.
