125 degree angle joint
29 Mar 2009
Berkshire
I'm building a timber frame office and being on my own I'm constructing wall panels then lifting then into place. I've now come to a part where two adjacent exterior walls meet at 125 degrees but am unsure how to angle, cut or joint the two vertical uprights of each panel[/b]
ah, can't do that as I need the uprights to fit the exterior WPB, subsequent cladding and then plasterboard on the inside...
do a bit off calculation then make up "wedges " from2x2" to give the angle you need and place every 12-16"
